Need help quick - How do I pull the crank pulley off?
Old May 3, 2003 | 04:59 PM
wifehatescar's Avatar
wifehatescar
Default Need help quick - How do I pull the crank pulley off?
In the middle of TB swap. I got the crank bolt out (finally) but how does the pulley itself come off???
I have tried to use a pulley puller but they don't look like they are designed for this. I really don't want to pry it off. Help!
1998 GSR.
Old May 4, 2003 | 03:42 PM
dubcac's Avatar
dubcac
I
Assuming you took the belts off, you should be able to pull it off. Maybe try to jar it loose with a dead blow hammer.
Old May 4, 2003 | 03:45 PM
AP2's Avatar
AP2
Moderator Alumni
I should slip right off. If not, gently tap it with a rubber mallet.
Old May 5, 2003 | 06:47 PM
MikeR's Avatar
MikeR
the pulley is keyed and not tapered like other oem's, once belts are off and bolt out there is nothing but a seized key to hold you back, lube it up with penetrating oil and smack that bznitch up
