what grade OIL goes in my GSR?
Old May 3, 2003 | 07:57 AM
Clean00GSR's Avatar
Clean00GSR
B18c1 >*
Default what grade OIL goes in my GSR?
does 5-w30 work? or does it have to be 10w-30
Old May 3, 2003 | 08:15 AM
EG_Oto's Avatar
EG_Oto
5w 30
Old May 3, 2003 | 06:23 PM
matdvd's Avatar
matdvd
I tend to let the weather dictate what would work best for the car.
In the winter, I go with the 5W, usually synthetic or blend. That way you get good flow early, when its cold and thick, and get the least amount of initial wear at start up.
In the summer, I'll go back to the 10W, just because it is fairly warm already from the get-go, and I know I'll be driving the thing really hard, and want that little bit more of thickness between the parts. I never see a MPG change. And if I did, I'd chalk it up to my harder driving habits anyway.
Old May 4, 2003 | 02:58 PM
ntegravtec's Avatar
ntegravtec
PENGUIN!
i talked to my mechanic about that.. if you're in SoCal where the weather doesn't change that much.. go with the thinner oil for newer engines.. but if you've got an older engine (like.. 50k+ miles) go with a thicker oil to help preserve its condition.
Old May 4, 2003 | 03:34 PM
AP2's Avatar
AP2
Moderator Alumni
If the weather in your area doesn't go below 40 degrees, then you'll be fine with 10-30w oil.
