what is the size of stock 96 gsr wheels?
Old Apr 15, 2003 | 12:59 PM
Snoopy's Avatar
Snoopy
been there done that
Default what is the size of stock 96 gsr wheels?
Old Apr 15, 2003 | 01:03 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
15x6"
Old Apr 15, 2003 | 01:12 PM
Snoopy's Avatar
Snoopy
how well would a 225 tire fit on that?
Old Apr 15, 2003 | 05:06 PM
XSrcing's Avatar
XSrcing
not very well. that is almost a 9 inch wide tire.
Old Apr 15, 2003 | 05:19 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
I believe 205s are the widest you could go on that rim. BTW all GS-R wheels are 15"x6".
Old Apr 15, 2003 | 06:52 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You can get a 225/50-15 tire on there but it will be bulging out a fair bit. I wouldn't do it unless you're going with something with a very stiff sidewall.
Most tire manufacturers list a wheel width range for each size of a particular tire. There's the "measuring rim width" which is the wheel size that you have to mount the tire on to get the quoted width spec, and then a range of widths that the tire can be reasonably mounted on.
Old Apr 15, 2003 | 07:04 PM
drive4show's Avatar
drive4show
I checked out the ES100 dimensional data, found on page 2 of
http://www.yokohamatire.com/pdf/avses100.pdf
205/50R15 has 6.5" Measuring Rim Width, with 5.5-7.5" Approved Rim Width.
225/50R15 has 7.0" Measuring Rim Width, with 6.0-8.0" Approved Rim Width.
So 225s will technically fit on the stock 15x6 wheels.
After reading this board, I decided to go with the 205s like everybody else; MrFatBooty knows his stuff.
On the other hand, you could try 225s and tell us the results! :thumbup:
Old Apr 15, 2003 | 08:11 PM
reno96teg's Avatar
er..
Old Apr 16, 2003 | 11:42 AM
Snoopy's Avatar
Snoopy
reason i ask is cause my brother has a set of 225/50 bfg drag radials on stock 96 rims. he's been rolling around on them for a few weeks.
Old Apr 16, 2003 | 02:34 PM
drive4show's Avatar
drive4show
Default So what does Spike say about the 225s?
Spike = Snoopy's brother in Peanuts.... eh, never mind.... :ugh:
I ended up with ES100s in 205s; comments on tirerack.com talked about soft sidewalls, and the need to properly inflate the tires. Much better ride at 40psi than 34psi (tires say don't go over 35-36psi when mounting with sealant bead).
I'm guessing it would have been a worse ride with 225s. Dunno about the bfg drag tires.
So, what does your brother say?
