98 GSR ?s
Old Jul 2, 2010 | 09:43 AM
gingas's Avatar
gingas
Default 98 GSR ?s
Hope everyone doing good. Getting ready for this 4th of July holiday weekend.
These my questions I have:1)I need a rear motor mount. 2)When I'm standing still at a light then take off car hesitates some before accelerating. Is this because of my rear mount being bad? 3)When shifting to 2,3,4 etc its hard going in gear not smooth like use to. Is that sign of a bad slave cyl or whole clutch assembly. BTW I have 181K on speedo.
Any info would be greatly appreciated & be safe & enjoy your holiday safely
Thankyou
Old Jul 2, 2010 | 03:22 PM
Lynxs1981's Avatar
Lynxs1981
The hesitation could be several things; ignition/fuel related, even a dirty air filter. Never heard of a bad mount causing hesitation. As to the shifting, I would check the clutch fluid and trans fluid; being a little low in the trans will cause all kinds of shifting issues.
Old Jul 2, 2010 | 08:52 PM
gingas's Avatar
gingas
Well my dizzy is 1yr old. The air filter pretty clean. As for my trans. fluid I just had it changed in April. My clutch fluid pretty good also. So, I guess its maybe my clutch itself.
Old Jul 3, 2010 | 01:50 PM
cruzalekz's Avatar
cruzalekz
check the clutch fluid, if its full, could be a worn out clutch cause it affects all gears.
Old Jul 4, 2010 | 01:55 AM
Lynxs1981's Avatar
Lynxs1981
Yea, if the clutch was worn out it would affect all gears, not just 2-5.
