Help with computer message
Old Mar 27, 2003 | 01:29 PM
djPaul's Avatar
djPaul
Got JC
Default Help with computer message
I've got a 89 Integra (my work car) and after I ahve changed a timing belt, it never working right, in a nutrual it just shut off, and computer blinks 9 times, which means something like #1 cylinder positons.
Any ideas how to fix it?
Old Mar 27, 2003 | 01:31 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
check your timing and all your ignition stuff.....maybe knocked something loose......
Old Mar 27, 2003 | 01:32 PM
djPaul's Avatar
djPaul
Got JC
Already did, the timing is fine, but for some reason my valves a nocking.
Old Mar 27, 2003 | 03:58 PM
90'RS's Avatar
90'RS
Well if the valves were not knocking before the change then the timing must be off or you did something that your not telling us.
Old Mar 27, 2003 | 04:00 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
did you check with a light or just looking at it.....timing isn't the easiest thing to get perfect.....sounds high if the valves are making noise....
Old Mar 28, 2003 | 06:51 AM
djPaul's Avatar
djPaul
Got JC
I checked with a timing light and even tried by changing a position of a ditrubitor, still doesn't help.
But when I looked in the book, I found out that the same message #9 could be as "#1 cylinder position" and "purge control valve". Sounds familiar?
