HELP Tech Infor Needed: !!!!!
Old Mar 23, 2003 | 08:26 PM
SiqGSR's Avatar
SiqGSR
Default HELP Tech Infor Needed: !!!!!
the spindle nut that is in the dead center of the rotors. The big one... .... well i need to know how much torque is needed to tigthen them down.
Thanks in advance
Old Mar 23, 2003 | 08:28 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
no book in front of me, but i'd guess somewhere around 75lbs....lugnuts are more than that, but there is a place in the axle where you bend the inside lip of the nut into it with a punch....it won't come loose if you just tighten the shit out of it....can't strip it unless you've got crappy tools.....i've never torqued mine though....you can also use the temporary loctite
by the way, i've done at least 500 hundred jobs where i had to loosen/tighten it.....never a problem....get a breaker bar and tighten it until you bust a nut, or get an airgun with 125psi of air pressure and hammer the hell out of it...
Old Mar 23, 2003 | 08:37 PM
SiqGSR's Avatar
SiqGSR
wont mess up the bearings or anything by tightening too much?
Old Mar 23, 2003 | 08:39 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
not unless you are the strongest human in the world or have a super air gun.....so NOPE.....just tighten it like you would a lug nut, make sure the axle is in good and tight, then use a punch or screwdriver to knock the lip into the notch on the axle.....really simple...i wouldnt even worry
Old Mar 25, 2003 | 01:54 PM
kento's Avatar
kento
actually, i think it's 110ft/lbs ...
Old Mar 26, 2003 | 01:55 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The Helms manual says 134 lb/ft and to not reuse the spindle nut.
Old Mar 26, 2003 | 02:03 PM
fizzbob7's Avatar
fizzbob7
90 accord h22a
axles should come with new ones, if not, then reusing the old one won't hurt at all, just make sure you get the lip punched in the notch good......you can torque it with a wrench or just tighten the shit out of it.....
