Window Tint Stripping
Old Mar 23, 2003 | 04:50 PM
ueb0258's Avatar
ueb0258
Default Window Tint Stripping
Does anyone know of any easier way than soap and water to take the sticky off from window tint after you pull the tint off?
Old Mar 23, 2003 | 05:10 PM
FromTheBottom's Avatar
FromTheBottom
Driver of Trains
I first wiped on some ammonia to soften the film. Then used a razor blade to get all the glue off. Remember to replace the blade often because it will dull rather quickly, and I kept spraying a water & soap solution to keep everything from drying out.
Old Mar 23, 2003 | 05:16 PM
b00gers's Avatar
b00gers
goo gone works really well to remove old adhesives really well.
after using it, be sure to rinse it with soap and water because it can leave behind some residue.
Old Mar 23, 2003 | 05:49 PM
Sportmode's Avatar
Sportmode
goo gone takes FOREVER. Save your self some time and buy some steel wool and windex or soapy water.
Old Mar 23, 2003 | 05:50 PM
Sportmode's Avatar
Sportmode
btw im speaking from personal experience here
Old Mar 23, 2003 | 06:40 PM
b00gers's Avatar
b00gers
takes forever?
i usually have good experience with them. i used goo gone to take the dried double sided tape off when i sold my body kit.
Old Mar 23, 2003 | 11:27 PM
Sportmode's Avatar
Sportmode
Originally posted by WiLL
takes forever?
im talking about the sticky adhesive crap that the tint leaves behind when you take it off your windows.
maybe mine were just a pain in the ass because the tint had been on the car for 5 years before i bought it.
Old Mar 24, 2003 | 03:44 AM
ben1233's Avatar
ben1233
Try to get your hands on a steamer. (You know, the thing you use to take off wallpaper) It works pretty well and doesn't take all that long. I used it on my front two windows, and only one little area still has residue on it, and goo gone could fix that quickly.
BTW: This is the best and fastest way to do it.....Good luck.
Old Mar 24, 2003 | 10:59 AM
randomtask77's Avatar
randomtask77
Wanderer
I've also heard that Simple Green does a pretty good job on the removal. But I think that the best technique is the steam trick.
