Serious Overheating Problem
Old Feb 18, 2003 | 07:54 PM
AcuraFiend's Avatar
AcuraFiend
Default Serious Overheating Problem
1994 teg gsr 125k mi:
the other day i changed oil/filter, replaced plugs(with copper ngk's), checked wires, drained radiator(not block) and refilled, bled, etc. added some chevron injector cleaner and called it a night.
the next evening as i was driving home i glanced down and realized the temp gauge was as far into the red as it could get and overheated as i pulled into my driveway(sending coolant everywhere, i hate that sheit). After the car cooled i pulled off the radiator cap only to find it had broken and lodged itself in the neck of the radiator. Pulled it out, drained the radiator, and replaced the cap. Problem solved right? Nope, took her out for a test drive which went well just cruising around (50-60mph, shifting ~4k or so, being nice in general) but when i would get on the engine(WOT) the temp gauge began to climb rather quickly. Take the load off the engine, turn on the heater and it would drop back down but as soon as i put it back in gear and put a load on the engine it would climb again.
Whats the issue here? I didnt realize changing out coolant could cause a friggin cooling system break down. Only thing i can think of is that a chunk of the radiator cap made its way to the thermostat and caused it to malfunction in some way or coincidentally it just went out around the same time. Any other thoughts/suggestions would be appreciated. i am not very familiar with the ins and outs of the cooling system so any help is useful.
Thank you
Ryan
Old Feb 18, 2003 | 08:56 PM
jeff's Avatar
jeff
what color is the exhaust smoke and what does it smell like?
also, check the color of your oil.
Old Feb 19, 2003 | 03:40 AM
90'RS's Avatar
90'RS
Did you bleed the system again after you had to refill it when the cap busted? I would also change the thermastat since it's not to expensive anyways.
Old Feb 19, 2003 | 10:38 AM
Taiwanze7's Avatar
Taiwanze7
first thing that popped into my mind is thermostat... are the fans on the car turning on? Do you know if the water pump is working?
Old Feb 19, 2003 | 02:16 PM
Jokieman31's Avatar
Jokieman31
If not the thermostat, have it flushed by a professional.
Old Feb 19, 2003 | 02:48 PM
drdavidge's Avatar
drdavidge
check the thick tubes while the car is cold, make sure nothing is in there. and then check the thermostats, and if that dosent find the problem, check for leaks and then have a mechanic check it out
Old Feb 22, 2003 | 06:19 AM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
follow where the bottom tube goes to (probably behind) thats where your thermostat is, now check those 2 bolts holding the thermostat on, 1 of mine was tight and the other one wasn't so i was spraying allll over my engine bay, or if thats not the case you may need a new gasket, or new gasket around your thermo... but anyway post where all the coolant is coming from?
Old Feb 25, 2003 | 12:26 AM
kidM0UA's Avatar
kidM0UA
thermostat might be stuck closed
