Fuel Pressure for GS-R?
Old Feb 4, 2003 | 02:56 AM
95' "Ruby" GS-R's Avatar
95' "Ruby" GS-R
Default Fuel Pressure for GS-R?
Hey everybody.
I have done numerous searches within this site and on the internet on this subject, however I am unsuccessful in my quest for knowledge.
Can anyone give me a definitive answer on what the Stock fuel pressure is for a 94-01 GS-R?
I'm trying to set my fuel pressure to stock settings and I was an idiot when I installed my B&M for not checking the stock fuel pressure.
There are answers to this question in the posts, but no one seems to be absolutely positive.
Thanks
Old Feb 4, 2003 | 06:59 AM
Outxider's Avatar
Outxider
X-Motoring
idle should be 38 and wot is 41-42. thats off of my head.
late
Old Feb 4, 2003 | 09:18 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Yup, that's right.
Old Feb 4, 2003 | 08:55 PM
95' "Ruby" GS-R
Thats a bunch. What happens if your run lean besides decreased performance?
Old Feb 5, 2003 | 03:34 AM
JimBlake's Avatar
JimBlake
My Helm book says 48 to 55 psi differential above manifold. (40-47 psi for non-VTEC engines.)
If you don't have a differential gauge, disconnect the vacuum hose from the FPR & plug it. FPR hose nipple is open to the air, & the hose is plugged so you don't have a vacuum leak into the manifold. Then use a normal fuel pressure gauge.
Running lean will increase combustion temperatures. You'll fail NOx, but get lower CO & HC.
If your fuel pressure is low, you won't necessarily run lean. Your O2 sensor will measure it & ECU will try to compensate by increasing injector duty cycle till the O2 sensor is happy.
Old Feb 5, 2003 | 04:47 AM
95' "Ruby" GS-R
Thanks again for the replies.
