Wheel size
Old Jun 19, 2002 | 07:59 PM
cefurod's Avatar
cefurod
Default Wheel size
Does anybody know if this wheel spec will fit the integra:
45mm offset
4X100 bolt pattern
54mm hub diameter
6" wide front
6.5" rear
Old Jun 19, 2002 | 08:10 PM
AP2's Avatar
AP2
Moderator Alumni
Affirmative. Just as long as the Integra isn't a Type-R, they will fit.
Old Jun 19, 2002 | 08:16 PM
cefurod's Avatar
cefurod
Default rims
Thanks. Do you know the LS stock rims specs?
Old Jun 19, 2002 | 08:23 PM
AP2's Avatar
AP2
Moderator Alumni
14x6"
4 x 100m lug pattern
Old Jun 20, 2002 | 08:03 PM
cefurod's Avatar
cefurod
Default offset
Someone said any offset above 42 would cause the tire to rub against the inside. So is 45mm offset too high for the integra ls?
Old Jun 21, 2002 | 11:29 AM
StepOnIt's Avatar
StepOnIt
that only applies if the car is not lowered too much...I would check that set up out with someone working in this field...don't just listen to some "opinions" (if i may say so).
Better check it out with someone who works in this field and make sure you won't have any surprises.
