Help! Clutch/Tranny problems...
Old Jan 6, 2003 | 05:59 AM
swtchink13oi4u's Avatar
swtchink13oi4u
Default Help! Clutch/Tranny problems...
Something is definantly wrong with my car. When the car is off I could put it into gear easy but sometime when turning on the car and trying to put the car in any gear it won't even go in! I know it not my tranny fluid because I just recently changed it. Also when I could drive the car, it very hard for me to shift it into gear..it like I have to use my force to shift it into gear n no it don't grind so it not the synchro. Also I put the car in fifth gear and smash on the gas and the rpm didn't rise so it was normal...Help!
Old Jan 6, 2003 | 06:17 AM
newgsrdriver's Avatar
newgsrdriver
Sounds like a fluid problem to me. Check if your master and/or slave cylinders are leaking. Master is on the firewall in front of the driver, you may have fluid leaking on the inside as well.
Slave is on the front of the tranny. Check for leaks and doublecheck your fluid level. Did you bleed the lines?
Old Jan 6, 2003 | 02:28 PM
swtchink13oi4u
Default ..
Nope I did not see any leakage and yes I bleed the clutch already. I'm thinking that it might be the clutch disk spring that broke off or loose or something but Iono...
Old Jan 6, 2003 | 03:34 PM
ShaolinLueb's Avatar
ShaolinLueb
hmmm just take it to a mechanic, sure it costs money but still it beats the hassle and saves you time. then if you can do it yourself, do it.
Old Jan 6, 2003 | 06:18 PM
RpG~^_^~LauRnO's Avatar
RpG~^_^~LauRnO
keep us posted
i think i have the same problem as yours..
but my case involves more craps.. i did auto to manual on mine.. ~
Old Jan 7, 2003 | 07:11 PM
swtchink13oi4u
Default hey
Hey I finally figure out my problem....It was my clutch..took it apart and oy boy..nothing but scratches..and it was pretty worn out so went and replaced it..there you go.
Old Jan 8, 2003 | 12:35 AM
RpG~^_^~LauRnO
Default Re: hey
what's the mileage on your car and the clutch?
mine was brand new.. about 8000 miles on it.. on my 2001 Teg
Old Jan 8, 2003 | 04:46 AM
swtchink13oi4u
Hmm if your car were brand new then I doubt it would be the clutch..My car were up at 145000 hehe..
Old Jan 8, 2003 | 05:56 AM
RpG~^_^~LauRnO
yeah man..
well i will try to replace the bearing and see what happens~
Good for you man.. you got yours fixed
