low idle
Old Dec 19, 2002 | 09:02 AM
ziggaman's Avatar
ziggaman
Default low idle
just curious what could make my car do this. when i stop driving my car will idle down to 1k rpm where it should sometimes. and sometimes when i am rolling to a stop in neutral the rpms will go down to 0 and bounce back up to 1k and then back down again. and sometimes it will get under 500 and it kinda sounds like its going to stall. if its doing this and i turn on the a/c or heat the rpms go to normal. i have my fuel pressure regulator set @ 48 psi. what the hell is causing this.
Old Dec 19, 2002 | 09:12 AM
LT's Avatar
LT
The deer had to die!
hmm...check for a vacuum leak - that can cause idle drops. Also, i see your GSR is a 97 and it shouldn't happen yet - but, the IAC (idle air control) valve may be going out of whack.
Old Dec 19, 2002 | 11:30 AM
ziggaman's Avatar
ziggaman
WHERE IS THE IDLE AIR VALVE LOCATED?
Old Dec 19, 2002 | 12:54 PM
reno96teg's Avatar
what's with all the people typing in CAPS lately?
Old Dec 19, 2002 | 01:34 PM
jclau00's Avatar
jclau00
cause they were trying to hit the tab button but hit caps lock instead and didn't realize it? :dunno:
Old Dec 20, 2002 | 09:16 PM
LT's Avatar
LT
attached to the throttle body - on the back.
Old Dec 20, 2002 | 10:13 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
http://webpages.charter.net/mrfatboo...e%2011-101.jpg
Check out the first picture on the left.
