help, i can't decide.
if i have enough money to do only ONE of these, what do you guys think i should do first,i can't decide?
replace timing belt/water pump. take car to dealer and have my cars problems finally figured out(throwing codes 22,41,16,running rich/slow)been trying to figure out code 22 for about 5 months. get a nice pioneer amp and alpine sub/box for $250 total(christmas special on base-ends on the 22nd)normally $550. get passenger side rear quater panel replaced-$1000(long story,sum1 ran into me and the whole panel looks so unbelivably horrible right now,allready had frame pulled back. i have a 95 2door gsr with 86,000 miles. :confused: |
get the side rear panel fix
I would fix the things that are wrong with the car before getting a stereo system. If you need a timing belt and water pump do that before the timing belt breaks and yoy screw up your engine.
i would say timing belt and water pump first. then fix the quarter panel. and lastly, get the stereo.
Do the timing belt/water pump first, if you leave those and your timing belt snaps then your not gonna be a happy soldier.
timing, codes, panel, stereo..
why are we even debating what should have priority :confused: |
Originally posted by LT6916 timing, codes, panel, stereo.. why are we even debating what should have priority :confused: |
Maintenance comes first.
Do the timing belt and water pump, that can cause you much more trouble later on down the line. Priorities after that should be to fix the codes and then the body work. |
those codes may be fixed when the timing belt and water pump are replaced.
for those who don't know the codes:
22 - VTEC Oil Pressure Switch 41 - H025 Heater 16 - Fuel Injector |
| All times are GMT -8. The time now is 01:27 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
