Car threw a code, now what. Help please :o
Old Oct 12, 2008 | 06:36 PM
b00gers's Avatar
b00gers
Default Car threw a code, now what. Help please :o
The check engine light just came on. I jumped the harness and it threw 7 long blinks. Searching HAN, it seems to be a problem with the automatic trans axle.
What should I do now?
Are there more detailed codes to be read? If so, will taking it to a place like Auto Zone or Kragen get that information? Thanks
Old Oct 12, 2008 | 06:42 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Vato Zone, esse.
Pull the DTC code.
If D4 is blinking, theres a different service connector (under the driver's side kick panel) to pull error codes for the transmission.
If it isn't, scan from the OBD-2 port. It'll probably be P0122 or P0123, both of which indicate faults with the throttle position sensor.
Old Oct 12, 2008 | 06:45 PM
b00gers's Avatar
b00gers
Thanks. I just checked the D4. It is not blinking.
What does a TPS fix look like
Old Oct 12, 2008 | 06:51 PM
TheOtherDave™
Apathy Kills
If you don't have a short in the wiring, it's a remove-and-replace kind of job.
The sensor bolts to the throttle body and measures the position of the throttle (obviously).
It should read 5V+ with the throttle opened fully and about .5V+ at idle.
If you have (or can get) a 1997 DC4 Helms manual, check page 11-59 for the flowchart.
First things first, though. Confirm that you've got a P0122 or P0123 error.
Old Oct 13, 2008 | 07:42 PM
Lynxs1981's Avatar
Lynxs1981
What year car? I know on the later models, the TPS sensor is "not replaceable". The factory uses a stupid special kind of fastener to attach to the TB.
Old Oct 13, 2008 | 10:25 PM
b00gers's Avatar
b00gers
Its a 1999 GS sedan
Old Oct 13, 2008 | 10:28 PM
dubcac's Avatar
dubcac
I
From the helms:
"Automatic Transmission malfunction with the automatic transmission controls"...doesn't sound like TPS to me. The TPS has its own code.
I think it's probably just a weird reading the ecu got from a sensor, so it tripped the code. Reset the ECU and see if it comes on again.
Code from CEL blinking > vato zone reader code
Old Oct 13, 2008 | 10:29 PM
b00gers's Avatar
b00gers
Auto Zone dont even read codes anymore. They wont even rent out the tool to
Old Oct 14, 2008 | 01:33 PM
Lynxs1981's Avatar
Lynxs1981
Really? The Zone out here does. Have an advanced auto or anything else nearby?
Old Oct 19, 2008 | 09:21 PM
b00gers's Avatar
b00gers
They told me a recent law was passed in CA. I dont know how true it was. But I got the code read, and I got:
0700 and 0740.
:thinking: I got the code cleared and so far the light is still off. I am going to see if it comes back on.
