lets talk about back pressure....
Old Dec 10, 2002 | 01:18 PM
B18C1TEG's Avatar
B18C1TEG
Default lets talk about back pressure....
Okay heres what gets me.......you dont want any back pressure, correct? Well if thats true then why is 3" exh too big for a naturally aspirated engine? Like running open header, no back pressure and more power, but with 2.5' exh and 3" exh the 2.5" is considered better....why?
Will some knowlegable person(Mrfatbooty for ex.) please help me answer this question?
Thanks alot
-Chase
Old Dec 10, 2002 | 01:39 PM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
its all about exhust velocity. You want the least amount of back pressure, but you want the exhuast to flow quickly. Having a smaller diameter exhaust will create more velocity than a larger exhuast, which is why you can loose power when you get too large of an exhuast, of course if you get too small of one you have back pressure which is bad. The key is to find something in the middle that is small enough to have good flow, but not so small that you choke your engine.
Old Dec 10, 2002 | 01:42 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Check out this thread as well:
https://www.honda-acura.net/forums/s...e&pagenumber=2
Shingo
Old Dec 10, 2002 | 04:11 PM
drdavidge's Avatar
drdavidge
check out the exhaust tech articles at the very bottom, this answers EVERYTHING: http://www.team-integra.net/sections...les.asp?Show=1
got pictures and GOOD explanations..check it out.
Old Dec 10, 2002 | 06:50 PM
qtiger's Avatar
qtiger
Cliffs notes:
Backpressure BAD. Exhaust velocity GOOD.
If maximum exhaust velocity was possible without backpressure, the world would be a better place. However, that doesn't exist. You want a combination of lowest possible backpressure and possible highest velocity.
Old Dec 10, 2002 | 06:53 PM
drdavidge's Avatar
drdavidge
more cliff notes: you want the diameter to be big enough for the exhaust gasses to flow at the highest rate possible before being restrained, basically what he said above
Old Dec 11, 2002 | 03:21 PM
SlprTeg's Avatar
SlprTeg
Shingo
Hellsing ownz me :thumbup: I only wish they made more, 12 (i think) isnt enuf
