Lets talk comp. ratios on ls/v-tech??
Old Nov 30, 2002 | 10:27 PM
hep_kitten57's Avatar
hep_kitten57
Default Lets talk comp. ratios on ls/v-tech??
Im building a street turbo ready ls/ v-Tech. and im not quite sure what i want to set the comp. ratio to. I want to boost under 20. Any ideas??? E-mail me please with suggestions. Thanx.:yumyum:
Old Nov 30, 2002 | 10:37 PM
Snoopy's Avatar
Snoopy
been there done that
9:1 should be low enough and learn to spell ls/vtec or you're gonna get flamed.
Old Dec 1, 2002 | 12:05 AM
cory's Avatar
cory
just use your stock B18B pistons.
Old Dec 1, 2002 | 05:02 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
B18B pistons in an LSVETC with a B16/B17/B18C5 (PR3) head will yield a 9.55:1 CR, with a B18C1 (P72) head 9.73:1.
Figures plugged in from here: http://www.c-speedracing.com/howto/c.../compcalc.html
With a PR3 head I would reccomend pistons with a dome displacement of around -5.0 cc, with a P72 head around -6.0 cc. In either case that will put you around 9.25:1 CR which should be reasonable for moderate-to-high boost levels assuming proper fueling.
You say "under 20" pounds of boost--on a stock Honda block you don't want to go past about 12 psi without installing new sleeves. Golden Eagle, Darton and others sell higher strength sleeves to be installed in place of the stock ones.
But, since you didn't bother to spell VTEC right (you said v-tech, i.e. the maker of cordless phones) I'm a bit skeptical.
