spark plug wires stuck?!!!!
Old Nov 26, 2002 | 07:28 PM
wannakno's Avatar
wannakno
Default spark plug wires stuck?!!!!
my plug wires are stuck I can get them off the plugs. I need to change the plugs but dont wanna damage the plug wires? help
Old Nov 26, 2002 | 07:42 PM
90'RS's Avatar
90'RS
I would try to twist on the boot to see if that will loosen them enough to take them off. If this doesn't take care of it then I would have to say that you need to buy a new set of wires also.
I have never heard of the wires getting stuck on there to the point of not being able to take them off when was the last time you change them?
Old Nov 26, 2002 | 07:44 PM
DB7 2.0's Avatar
DB7 2.0
Banned
werd
Old Nov 27, 2002 | 04:17 AM
LT's Avatar
LT
The deer had to die!
don't be a child...just pull the damn muthafuka's up!
Old Nov 27, 2002 | 05:20 AM
XSrcing's Avatar
XSrcing
use some of them muscles!
Old Nov 27, 2002 | 09:49 AM
95TEGyoure it's Avatar
95TEGyoure it
Billy Sexcrime
"wiggle it.....just ah little bit"
Old Nov 27, 2002 | 12:10 PM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
yeah, I think you just aren't pulling hard enough....
Old Dec 1, 2002 | 05:23 AM
TTZ's Avatar
TTZ
If you have to pull very hard you will damage the wires to some degree. If they are stuck it is most likely due to corrosion anyway. I recommend wire replacement. Abuse them as much as you want with tools to remove them, they need replacement anyway. Replacement wires are really quite inexpensive.
