torque specs
Old Nov 22, 2002 | 10:08 AM
b00gers's Avatar
b00gers
Default torque specs
anyone know the torque specs to the susp bolts? all the ones nesscary to sway the springs and shocks?
will bolts that are too tight make the bushings squeak?
thanks
Old Nov 22, 2002 | 10:36 AM
Hua's Avatar
Hua
Dalene Kurtis lover
You should have applied silicone paste to the rubber top hats where they meet the spring.
If your suspension is squeaking, apply white lithium grease to the sway bar bushings and see if that helps.
Old Nov 22, 2002 | 02:49 PM
Deludedteg's Avatar
Deludedteg
Would this work with a Ground control set up? Or is this something that should be done with any set up?
Old Nov 24, 2002 | 06:08 PM
Hua's Avatar
Hua
Dalene Kurtis lover
Applies to any setup.
Old Nov 24, 2002 | 06:49 PM
b00gers's Avatar
b00gers
anyone got the torque specs?
