Clutch pedal height adjustment
Old Nov 18, 2002 | 05:28 PM
Kaiz's Avatar
Kaiz
Default Clutch pedal height adjustment
Has anyone adjusted the height (from floor to pedal) of their clutch pedal? I've got my Haynes manual, but its not very descriptive (visually speaking). Do I do this up under the dash where the pedal pivots are? Or is it under the engine bay? Anyone know?
Old Nov 19, 2002 | 07:52 AM
95GS-R's Avatar
95GS-R
Um What?
The adjustment is made under the dash... but why does it need adjustment?? This is not something that requires regular adjustment and should remain in the same position. If adjusted improperly, you run the risk of either never fully engaging the clutch when the pedal is released, or never fully diengaging the clutch when the pedal is pushed. Either way will SIGNIFICANTLY shorten the life of your clutch...
Best idea is to just leave it alone
Old Nov 19, 2002 | 03:14 PM
Kaiz's Avatar
Kaiz
Well the problem was/is with the clutch/tranny itself. I've been to the dealer probably 20 times (they've already replaced the clutch/pressure plate/flywheel once due to defect) under warranty, and its still giving me problems. The Haynes manual says the pedal should be 6.5in from the floor, but its about 5.75in on mine. I don't know if this is a significant amount. My pedal also has A LOT of play in it (atleast a full inch).
Old Nov 19, 2002 | 07:25 PM
pomansouth's Avatar
pomansouth
you might want to check your fluid levels on your clutch fluid and make sure that it isnt leaking or anything to that effect and also make sure that the slave cylinder is good
Old Nov 19, 2002 | 08:17 PM
Kaiz's Avatar
Kaiz
There are no problems with the fluids.
