hydrolock help...
Old Nov 8, 2002 | 06:49 AM
b00gers's Avatar
b00gers
Default hydrolock help...
refer to https://www.honda-acura.net/forums/s...threadid=32821 for the story.
i got it to run now. it runs like nothing happened. should i still change the plugs and oil and what not?
what should i do now?
thanks.
Old Nov 8, 2002 | 07:38 AM
Daniel's Avatar
Daniel
Do a compression check, replace your oil. Not sure on plugs, but I'd do it just to be on the safe side. If your cylinders all read fine, get the oil/plugs replaced and go for launch!
Old Nov 8, 2002 | 07:39 AM
antarius's Avatar
antarius
Large Member
Like I said.
I wouldn't do a damn thing.
Keep an eye on it and make sure its running properly, gas mileage is fine, etc.
You're fine.
Old Nov 8, 2002 | 09:51 AM
b00gers's Avatar
b00gers
alright, compression test goes on my list of to dos.
thanks.
Old Nov 9, 2002 | 10:06 PM
fidracer's Avatar
fidracer
Similar thing happened to me a year ago. Drove through a small puddle at 20 mph (right front wheel hit it). Engine started sputtering, then died. I fired it up again, it started, then revs fell and it died. Then I turned it over and it wouldn't catch. I sat there for a few minutes wondering what to do (I was up in the mountains, no gas station for at least 20 miles, dark, raining, no cell phone coverage). Then I tried it again and it worked like nothing had ever happened.
Talked to a bunch of people about it (including my dealer) and the verdict was that water got in the distributer. No hydrolock or anything (my car is 100% stock). All it takes is a drop or two splashing in there and the car will die. After a few minutes, it dries out and everything works fine. Anyway, I hear a lot of people talking about hydrolock and frankly I think many are off base.
Old Nov 10, 2002 | 08:19 AM
b00gers's Avatar
b00gers
yea, i just called it hydrolock since that was the term i was most familiar with, even though the never never "locked".
i consider myself lucky on this one.
Old Nov 19, 2002 | 08:10 AM
95GS-R's Avatar
95GS-R
Um What?
This is NOT hydrolock. You're fine, don't worry about it. You have to suck up a LOT of water to have a problem.
