smooth runing engine
Old May 14, 2008 | 09:11 AM
Love2RedLine's Avatar
Love2RedLine
My 4th Acura
Default smooth runing engine
My gsr has a cammed b20. I was driving it on the freeway around 4000 rpm and I was wondering if thats too high of a cruising speed. I do not beat on my engine. Latley it hasn't been sounding quite as smooth. I hear a slight vibration and little clacking sound when I listen to the engine. A friend of mine said that its just my valves and it could be from me using the lower octane gas. Could this lead to a problem? I ran Sea Foam threw the intake manifold 3 times and the engine still sounds the same.
Old May 20, 2008 | 10:27 AM
jonesy9595's Avatar
jonesy9595
You have to run premium!!!
Do a valve lash
Old May 29, 2008 | 12:29 PM
whatinthe's Avatar
whatinthe
The Duke of Earl
Ooh Ooh Ooh!!! Its a bitch but tighten ur timing belt!!! I had the same problem. It sounded like I had gravel in my valvetrain and it didn't go away untill a replaced my water pump and set my belt with more tension than the spring cud provide. Shazam!!!
