Clutch squeak, changed master/slave cylinders, still not helping.
Old Apr 22, 2008 | 07:08 PM
chanus's Avatar
chanus
Default Clutch squeak, changed master/slave cylinders, still not helping.
Hi I have 00 Integra Type R and my clutch pedal has been squeaking when the car is warm.
I took it to my dealership twice, first time they said my master cylinder is leaking, so they replaced it and still squeaking. Took it in again the second time and they said they found the noise form slave cylinder and replaced it too. It is still squeak, any idea??
Please help.
Old Apr 22, 2008 | 07:13 PM
Lynxs1981's Avatar
Lynxs1981
Are you sure it's the clutch pedal squeeking? If it is, I would just spray it with some wd-40. There's several springs and bushings on the pedal that tend to squeek.
Old Apr 22, 2008 | 07:20 PM
chanus's Avatar
chanus
I don't think it is the pedal, I put my head under the dash and use my hand the press the clutch. It sounds like it is from inside not from the joints.
The strange part is that the noise goes away every day in the morning, and came back after I drove it to work. Somehow it needs to be somewhat warm, I think.
Old Apr 23, 2008 | 01:54 AM
A-series's Avatar
A-series
v-card member alpha
There's a writeup somewhere on the net about applying grease to the right spot to make the noise go away, I don't remember where, but if you search google you'll likely find it.
I think mine only makes the noise in the summer when it's humid, or at least only when warmer out. It doesn't bother me, many cars' clutch pedals make that noise at times.
edit: here it is http://www.honda-tech.com/zerothread?id=179021 forgot I had it bookmarked h:
Can't say for sure that's the cause on your particular car, but good luck.
Old Apr 23, 2008 | 02:06 PM
Lynxs1981's Avatar
Lynxs1981
Yea, I had an old civic that did it in the summer. My simple solution was to turn the radio up. But that does not apply to all situations, lol
Old Apr 27, 2008 | 12:14 PM
thetunersource's Avatar
thetunersource
mine did the same thing... nothin to worry about and no cure in sight.
