Water Pump question....?
Old Nov 1, 2002 | 06:31 AM
Heinz57's Avatar
Heinz57
Default Water Pump question....?
Last night my car overheated and there was no water in the waterpump. I refilled it with water and pored some water in the radiator. The engine was off and cooling down for about 45 minutes then I drove home for 50 miles. It didn't overheat at all, in fact it kept it's normal temperature. .....But these morning when I turned it on and drove it for 5 miles the temp stayed the normal stage but the water pump was empty. It drank all the water. My question is why did my car use up all the water in the pump? Whats the problem, can anyone help?
Thank You.
Old Aug 23, 2003 | 03:39 PM
REbornHONDAneer's Avatar
REbornHONDAneer
Honda Biased
u mean the "coolant reservoir"? Not the water pump right? U dont fill a waterpump.
If its draining your reservoir, you might have a leak, did you check for leaks? Let it run idle on a clean part of pavement in a parking lot somewhere. Lie on the ground with someone "observing" the temp so that doesnt go high. See if there are any drips of any kind on a consistant basis.
Dave
Old Aug 23, 2003 | 03:42 PM
REbornHONDAneer
Honda Biased
crap..i just realized that that post is almost a year old...heh :-)
Dave
Old Aug 23, 2003 | 03:44 PM
Amirked's Avatar
Amirked
did you just add water? and how many times did you only add water? the coolant .. which is in your radiator and coolant overflow tank should be a mixture of 50/50 water to antifreeze (the green stuff) you should go to a acura dealership to pick up a bottle of pre-mixed coolant. you could be boiling it off. check for leaks and check for white smoke out the tail pipe .. its either leaking, evaporating, or burning off. Get a new radiator cap while you are at it. .
Old Aug 27, 2003 | 12:24 PM
kidM0UA's Avatar
kidM0UA
Dave
wned:
Old Aug 27, 2003 | 06:18 PM
REbornHONDAneer
Honda Biased
LOL!
Old Aug 27, 2003 | 08:04 PM
AciDKinG95LS's Avatar
AciDKinG95LS
SOLD THE ALLUM. WING!!!!
lol
