Valve Question?
Old Feb 16, 2008 | 03:12 PM
Hot1990civ's Avatar
Hot1990civ
Default Valve Question?
Will Type-r intake valves fit my 1995 ls? and if so is it a good investment for my all motor build? thanks
Old Feb 16, 2008 | 04:39 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The ITR valves will not seat properly on a stock B18B1 head.
If you are having the head ported and new valve seats installed, then yes, ITR valves are a good option.
What cams are you running (or plan to)?
Old Feb 16, 2008 | 05:18 PM
Hot1990civ's Avatar
Hot1990civ
Stocks as of right now.
Here are the parts i have so far.
Eagle rods
ACL race rod and main bearings
12-7-1 comp domed pistons
Oem honda engine seal kit
Oem water pump/t-belt etc
So bottem end is pretty much set
Soon to buy skunk 2 intake manifold/blox 74 mm. TB
Im no good with top ends, i mean i work in parts at a subby dealership so i know about them pretty well. But when it comes to performance parts on the top im not too sure. so i apreciate your help man.
Old Feb 16, 2008 | 05:58 PM
TheOtherDave™
Apathy Kills
Eagle rods
No problem.
The Crower #62404-2 cam is a good place to start if this car is going be on the street at any point. (12.7:1 CR leads me to believe this is a strip & track car we're talking about.)
http://www.crower.com/cat/import/honda/cams/b18ab.shtml
You will need their spring and retainer set as well.
Old Feb 16, 2008 | 06:27 PM
Hot1990civ's Avatar
Hot1990civ
Just a hobby/summer fun car. Couple things, will i throw a cel with the higher lift, and will stock gears work fine? and will the machine shop have a problem timing it? because i know it is an interference engine.
Old Feb 16, 2008 | 07:08 PM
TheOtherDave™
Apathy Kills
I assumed you'd be well aware that 12.7:1 is a very high compression for 93 octane fuel and that you would need to upgrade engine management, fuel and ignition systems.
Unless you've got the budget to run a couple gallons of C16 along with 93 octane unleaded in every tank, you'd be better served by reducing compression to about 11:1.
But if you're committed to making 12.7:1 run on the street, I would begin by consulting with your engine builder. Find out which ECU tuning program he prefers and get a sense of his (or her) experience in tuning hi-comp N/A motors.
You're not going to have much breathing room when it comes to detonation. And even though you're running forged pistons and con-rods, severe detonation will fracture piston rings and write off a block in moments.
Old Feb 18, 2008 | 03:35 PM
jesusublime99's Avatar
jesusublime99
The Skunk2 IM port is only 64mm. There is no point in getting anything bigger than opening of your IM plenum port, think about it. Get a throttle body that matches the IM port size, or bore it out to match a throttle body, if possible.
