95 teg not blowin heat
Old Feb 15, 2008 | 11:39 PM
123Lizard's Avatar
123Lizard
Default 95 teg not blowin heat
Like the title says my ls isnt blowing heat but the temp guage is reading VERY hot, when i stop to check how hot the engine is by hand it just feels normal. Anyone know could be the problem?
Much thanks in advance.
Old Feb 16, 2008 | 05:13 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Your heater (heater core) has nothing to do with the engine and is a seperate issue. You can't "feel" the temp of the engine, how hot is "very" hot? Where is the needle on the guage? Does it fluctuate??
Old Feb 16, 2008 | 08:18 AM
A-series's Avatar
A-series
v-card member alpha
Sounds like your thermostat isn't opening up.
If it stays closed you can't get any heat inside the car b/c no hot coolant is flowing through the heater core, and it can't flow through the radiator to cool the engine.
If you temp. gauge ever gets near the red mark, and you can't get any heat (which could help cool it down), you should shut the engine off before it gets to the red if possible. Even if you're on the road, just pull over, open the hood to vent more heat, and wait a while until the temp. has dropped some before you try it again. You can do that over and over (though not the best for the engine) if you have to in order to get home, etc. just as long as you don't run the engine while it's in the red. (on some cars the temp. gauge can actually continue to climb some after it's been shut off, meaning it might climb higher and hit red before it drops, as long as you've turned the engine off before that happens you should be alright).
Old Feb 16, 2008 | 12:46 PM
123Lizard's Avatar
123Lizard
well thats exactly what happens, it almost hits the H, gonna replace the thermostat and see what happens. Thanks to everyone that replied, very much appreciated.
Old Feb 16, 2008 | 12:55 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
I'll second on the thermostat. Replace t-stat and while you're at it replace the coolant as well.
Old Feb 19, 2008 | 02:31 PM
Lynxs1981's Avatar
Lynxs1981
Any recent work done on it? Sounds like maybe you have some air trapped in the lines.
