How to advance timing....
Old Oct 19, 2002 | 05:27 PM
B18C1TEG's Avatar
B18C1TEG
Default How to advance timing....
How do I advance my timing to 18? Would I have to take it into a shop or what? Could someone who has tell me how they went about doing it? Thanks much
Chase
Old Oct 19, 2002 | 05:39 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Enjoy.
Old Oct 19, 2002 | 06:26 PM
ChixWitDix's Avatar
ChixWitDix
inside of your radio
what do you achieve by advancing your timing? i just want to know.
Old Oct 19, 2002 | 10:09 PM
pomansouth's Avatar
pomansouth
well if you advance it just a hair it gives you just a hair of hp and it has to run off of higher octane fuel
Old Oct 20, 2002 | 12:36 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
What year teg are you doing this on? I've heard it does absolutely nothing with OBDII
Shingo
Old Oct 20, 2002 | 09:24 AM
B18C1TEG's Avatar
B18C1TEG
its a 00' GSR
Old Oct 20, 2002 | 10:02 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The ECU even in the older cars has a complete timing map just like fuel. When the distributor is set to 16° BTDC on an OBD-I or older car, the actual timing map that's in the ECU is what happens. If you advance to say 18° BTDC, all you're really doing is adding 2° to every point on the map. That's on the non-OBD and OBD-I cars.
On OBD-II ('96 or newer) cars the ECU is able to detect that it's not getting the proper timing and "learns" to apply whatever sort of adjustment factor to get the values that are on the timing map. So if you advance the timing by a couple degrees, that advance will only last for a week or so and then the ECU learns how to dial it out. If power is removed from the ECU, it resets back to the base map. Some people with OBD-II Preludes have rigged up a system of relays to cut power to the ECU every time the car is shut off just so they can keep their advanced ignition timing. One problem with this is that if the ECU throws a code there's no way to check it since the memory is erased once the car gets turned off. It's not really worth the effort just to advance the timing by a couple degrees.
Old Oct 20, 2002 | 12:22 PM
B18C1TEG's Avatar
B18C1TEG
ooohh okay, thanks for the information!!
Old Oct 20, 2002 | 01:30 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Please use a timing gun guys and don't just eye ball advancing your timing.
Old Oct 20, 2002 | 02:06 PM
dubcac's Avatar
dubcac
I
You can advance timing on obd2, you have to jump the service connector by the ecu, putting the ecu into loop mode. It still works, I was running 4 degrees of retard for the nitrous and it never went back to stock on me.
