i need help with fixing my 94 integra ls
Old Feb 5, 2008 | 11:09 PM
speedo1's Avatar
speedo1
Default i need help with fixing my 94 integra ls
heres the problem there is water in side my engine but dont know where its commin from. i switch the manifold gasket but it wasnt it ......i think it might be the head gasket.......if so how do i take off the head..
Old Feb 6, 2008 | 06:11 AM
Lynxs1981's Avatar
Lynxs1981
Best advice, get a Helms manual. Comes in handy.
Old Feb 12, 2008 | 10:17 AM
mike_13_87's Avatar
mike_13_87
you have to take off the valve cover and the remove the cams to get to the head bolts. there should be 4,6, or 8 bolts dont remember. but when you get those out you will have to get new ones because they are stretchable bolts the old ones will not be good anymore. Then the head will come off. but before you reinstall the head you must remove any oil that is in the screw holes for the head bolts if not you will pull the threads on the block and it will be ruined. After that reinstall cams tourqe down everything to spec, set time , reinstall hoses etc.reset time then you will be good to go. good luck
Old Mar 16, 2008 | 07:53 PM
flappy188's Avatar
flappy188
O.G. SON!
i agree with the dude Above me, if you dont know what you are doing, i would probably let some one do it that does know, you dont wanna loose that head, because you didnt do something exact.. so yeah man, good luck with the head.
