Keeps stalling
Old Dec 30, 2007 | 05:17 PM
tegurit's Avatar
tegurit
Default Keeps stalling
Recently I Installed a new headgasket on my 96 GSR. I put everything back togather,(but maybe not the timing. Read on...) and when i started it up, it idle very low. In netural when i reved it everything seem fined. but once i engade the clutch and gaved it gas the engine stalled everytime. PLease help I dont want to pay an arm and leg at acura, and have it be some easy fix.
Old Dec 30, 2007 | 08:54 PM
2001TEGGSR's Avatar
2001TEGGSR
Double check your cam timing, ignition timing, and all other sensors & hoses that might have been disconnected in the process.
Old Dec 30, 2007 | 09:10 PM
HybridGarage's Avatar
HybridGarage
Does it only hapen when the clutch is pushed in
Old Dec 31, 2007 | 12:24 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sounds like the cam timing isn't right. Pull the belt off and try again. Make sure the crank lines up with the mark on the lower timing belt cover when both cams are at TDC.
