Flex Pipe needed for header installation
Old Nov 26, 2007 | 03:22 PM
Red_98_Civic's Avatar
Red_98_Civic
98 Integra GSR (stock)
Default Flex Pipe needed for header installation
I took my car to a local performance shop to have my 4-1 header put on. After a few hours of work i was told by the mechanic that i needed a flex pipe put on in order for the header to bolt up underneath. He said to take it to an exhaust shop and tell them i need a flex pipe put on at the same my header is put on. As anyone had the same trouble?
Edit: The car is a 98 Integra GSR
Old Nov 26, 2007 | 09:17 PM
RunningOnMT's Avatar
RunningOnMT
4Banger
No, if it's a quality built specific header it should be a bolt on affair. A header install should take 30-45 min. with jackstands and handtools. Look the merge pipe - it should have an o2 sensor bung for the 98+ integras. If no bung then you have a 94-07 header which is shorter.
Old Nov 27, 2007 | 06:51 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
94-99 GSR exhaust manifolds are the same with no O2 bung in them as both are in the cat. 94-01 LS and 00-01 GSR have a longer A-pipe and an O2 bung in the collector.
The header won't need a flexpipe unless the spring bolts where the header and cat meets are eliminated.
