Did Not Pass Smog! (High HC?)
Old Oct 27, 2007 | 10:38 AM
Stone2354's Avatar
Stone2354
VTEC
Default Did Not Pass Smog! (High HC?)
Hey guys, new here and new to Integras. Just got my first GSR 2 weeks ago and I took it in to get the smog done yesterday but it failed because it has "High HC at Idle." I dont know what that means and the mechanic really didnt explain it too well. I was wondering if anyone had any advice on how to lower that...what is "HC" btw. The max I could get was 100, and my car hit 159. Anyways, I wanted to know if there was anything I can do, or if taking it to a mechanic is the best choice.
Thanks in advance!
-Stone
Old Oct 27, 2007 | 12:41 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Thanks in advance!
-Stone
Welcome to HAN. HC stands for hydrocarbons. Your car is not running in tip top shape and so un-burnt hydrocarbons are entering the atmosphere and so the SMOG test is failing you and your being advised of that through the test.
I would do a basic tune up if not done already. Plugs, wires, cap, rotor, oil change & fuel filter. Run Honda top end cleaner through as well to clean out the motor of carbon build up as well. You can use seafoam too if you wish. I've used both and results are pretty much identical. Make sure the timing is correct as well. If you still fail after this, your cat most likely is taking a shit, took a shit or is severely lazy. You'll have to replace it. Then your car should be running tits, considering all you did prior to the change of cat.
Are you mechanically inclined? Will you be able to do these things yourself? Use OEM parts as well. They last a long time and fit right the 1st time.
Old Oct 28, 2007 | 10:29 AM
Stone2354's Avatar
Stone2354
VTEC
Cool, bro. Thanks! I'll take it to get a tune-up. I'll see if I can find the Honda cleaner, otherwise I'll just go with the SeaFoam.
Old Oct 29, 2007 | 08:13 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Alright then, check back when you get re-tested after the tune-up so we can see where your at.
Old Nov 1, 2007 | 10:34 AM
Stone2354's Avatar
Stone2354
VTEC
Ok, took it to a mechanic yesterday and turned out that all it needed was new thermostat and a new fuel evap cannister. They also cleaned out the engine of carbon built up which will result if better fuel economy and I must say the car feels excellent! What a difference it made! HC levels dropped dramatically. Previously at 159, not at only 9! Woo!
Old Nov 3, 2007 | 06:50 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Cool deal.
Old Nov 11, 2007 | 09:40 PM
tstock34's Avatar
tstock34
Default HC's
shoot I guess thats what I need to do.... my teg would not pass on HC's either.... I think the emission testing places are just trying to take our money! lol
Old Nov 12, 2007 | 11:06 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Threads merged.
Old Nov 13, 2007 | 12:56 PM
Difussion3's Avatar
Difussion3
Touge
Just pay them in order to pass, I'm sure they corrupt.
