Poping when Boosting...HELP!
Old Oct 19, 2007 | 08:59 AM
rugsr's Avatar
rugsr
How do my taillights look
Default Poping when Boosting...HELP!
So last night I was driving on the highway, just entered from a ramp, and felt like driving hard. Mad sure all temps were at normal before I dropped gears...they were...I did. I stepped on it in 2nd and around 6000RPM I felt a loss in power and heard POP POP. I was like WTF. So then I shifted into 3rd, gave it gas started boosting and again around 6000RPM it poped and I felt a loss in power.
Any idea what this might be?
Thanks guys
Old Oct 19, 2007 | 09:29 AM
FooD2000's Avatar
FooD2000
Still Water
Sounds like a misfire to me or maybe it's backfiring?
Old Oct 19, 2007 | 09:56 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
What are the spark plugs gapped to?
Old Oct 19, 2007 | 09:57 AM
rugsr's Avatar
rugsr
misfire?
bad spark plugs will do that?
They are only as old as this spring
well when i put them in they were gapped to .2 i believe...or maybe .25
NGK's
Old Oct 19, 2007 | 10:38 AM
Provocateur
On permanent hiatus
Originally Posted by rugsr
misfire?
NGK's
Yes, bad or improperly gapped plugs will cause random misfires, especially on boosted setups in the higher rpms. It takes 5 minutes to pull out the spark plugs. Check them and get back to us. It could also be an ignitor or ICM taking a crap on you.
Old Oct 22, 2007 | 07:54 AM
rugsr's Avatar
rugsr
going to try and check today.
its 80 degrees out in buffalo and being october...thats RARE!
ill take prob 1 last spin with the top down in the S2K and then check the plugs
Old Oct 24, 2007 | 08:11 AM
Scytale9's Avatar
Scytale9
Default MAP sensor
not a boost guy myself, but just got done reading some posts that mentioned MAP sensors causing that issue in boosted setups. if the boost raises the Manifold Air Pressure above the threshold of the stock MAP sensor, it should give a check engine light, and cause misfiring.
