b18b1 tune up
Old Sep 13, 2007 | 11:00 PM
Love2RedLine's Avatar
Love2RedLine
My 4th Acura
Default b18b1 tune up
My b18 is running a little rough. There isn't any nocks or pings, but the engine shakes and its a little noisy. When I checked my spark plugs I noticed oil dripping down the threads of the plugs. Im guessing that its a leak in my valve cover gasket. Does any one know if that could be causing my engine to run rough? My 92 seemed way faster than this 94. Can someone please give me some advice to of what to replace on my car to get it running smooth again? I know this is not how a b18 should running.
Old Sep 14, 2007 | 03:07 AM
dray's Avatar
dray
The first thing I would do is get a valve cover gasket kit and replace the gaskets. My 97 was running rough and i had the same problem, spark plug hole was full of oil because of a cut o-ring. Ive that doesnt fix it you could replace the spark plugs, wires, rotor button, cap and even run some sea foam through it(https://www.honda-acura.net/forums/s...ad.php?t=86584).
Old Sep 14, 2007 | 06:08 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
As far as the shaking goes, how do your motor mounts look? I had to change mine around 110k. They were hashed.
Old Sep 14, 2007 | 06:45 AM
dray's Avatar
dray
Could be your CV axles that is making it shake too, unless your just taking about you eninge which after i looked at you post does look like what you are talking about so..
Old Sep 14, 2007 | 05:54 PM
Love2RedLine
My 4th Acura
Thanx guys. Im gona do the regular tune up stuff, replace the valve cover gasket and try that sea foam.
