Vacuum Teeing Question
Old Aug 26, 2007 | 04:25 PM
MC-14's Avatar
MC-14
Tri-man
Default Vacuum Teeing Question
I'm teeing one vacuum source off the manifold for the fpr, bov, boost gauge, and 3 bar map sensor. I think this should be okay?
Old Aug 26, 2007 | 05:44 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It will be fine.
I would definitely recommend a vacuum manifold for two reasons, though. Firstly, you get a better vacuum source since you are tapping into the brake booster vacuum line and secondly, it will look much cleaner and make diagnosing problems easier. For $30, it really is a good investment.
Old Aug 27, 2007 | 05:29 PM
Spec R's Avatar
Spec R
also keep in mind that those cheap plastic tees dont hold up to heat and age very well.
DB Squad
Integra Forum Moderator
Old Aug 29, 2007 | 08:24 AM
MC-14's Avatar
MC-14
Tri-man
Yea I found out the other day when it was on the dyno. Brass fittings are the best
