GSR doesn't start, distrubutor problem i think
Old Jul 14, 2007 | 02:58 PM
jesusublime99's Avatar
jesusublime99
Default GSR doesn't start, distrubutor problem i think
My car decided not to start, we checked it for spark and there was none. I borrowed my friend's GSR dizzy, and it works just fine. I hope I don't have to pay for whole new one.
What parts inside the distrubutor can be checked and replaced?
Old Jul 14, 2007 | 05:20 PM
Fuse's Avatar
Fuse
Do you have a CEL???? I have just changed the sensers before if its a code. The coil and igniter can be changed easily.
I would take off you dizzy cap and see if you are getting sparks from your coil if you are it may just be the cap and or rotor.
If you are not you may just have a bad coil and or igniter.
If you have a volt meter with a hertz or h data function and ohms we can take a look at some things.
Old Jul 15, 2007 | 03:28 AM
jesusublime99
Thanks Fuse, with your info I was able to research how to test the coil, and thats what it was, a bad coil that measured at 9.7ohms when it should have been 12-19ohms.
There was no CEL. My friend gave me his coil from an old LS dizzy that measured 16.6ohms.
Old Jul 15, 2007 | 09:12 AM
Fuse's Avatar
Fuse
try it see what happens if it will not work let me know we can test some other tings.
Old Jul 27, 2007 | 06:37 AM
manimal15611's Avatar
manimal15611
I had the same thing happen to me I found out it was the ignition coil underneath the cap and rotor. Take the distributor off and replace the coil and ignition pack should work fine.
Old Jul 28, 2007 | 06:30 PM
myhdnromance's Avatar
myhdnromance
Flyboy
ok... different car.. lets throw in some twists....
mines doing the same thing...
but i havent tryed a new dizzy...
and mines blowing the pgm-fi/ecu fuse in the engine bay..
and ive replaced the coil pack.. and the cap/rotor.. and plugs.. and wires...
Old Jul 31, 2007 | 06:53 AM
Lynxs1981's Avatar
Lynxs1981
Check for a short before anything else.
