tegra elec. problems... could use some input please
Old Jul 12, 2007 | 08:41 PM
myhdnromance's Avatar
myhdnromance
Flyboy
Default tegra elec. problems... could use some input please
ok... i havent checked fuel.. but i know im not getting spark.. well as far as i know.. im going to check it again... the car turns over... but... doesnt fire....
ive checked the grounds.. ill do that again though.. ive also noticed that as soon as i go to turn the ignition on.. the ecm fuse in the engine fuse/relay box blows.... ive had problems with the data link connector cable burning up not that long ago.. i replaced it.. same resistance wire... so thats not the problem i dont think...
nothing else blows.. but i dont have interior lights/ power antenna...
if u have any ideas let me know...
thanks..
Jon
Old Jul 13, 2007 | 11:26 AM
KrazyAboutHondas's Avatar
KrazyAboutHondas
all motor or nothing
First of all, when did the problem first start, and was it fine before any previous work was done.If your ecu fuse is popped,you wont get spark or fuel, so try fixing the popped fuse issue first. Check all the wiring to your sensors, that are controlled by the ecu. I had the same problem and it was my O2 wiring insulation was busted and the wires were touching eachother, grounding itself out. So check your wiring. Let me know how it works out.
Old Jul 13, 2007 | 11:53 PM
myhdnromance
Flyboy
yeah the car was fine in aug.. then i blew my clutch hardcore... had it emergency (i got raped) repaired.. and the idiot didnt put a new flywheel in... soo that got fucked up on my way home... i got it home and parked it cause i left for the air force..
it was garaged till may when i put the clutch in it... it drove.. then it messed up this problem and stopped working... i think im gonna take apart the harness and see whats going on ...
Old Jul 14, 2007 | 01:31 PM
KrazyAboutHondas
keep me posted on how works out
Old Jul 14, 2007 | 09:47 PM
myhdnromance
Flyboy
pgm fi relay has a burned wire.. im trying to figure this out a bit.. its the pgm fi...pretty sure about that
