my car keeps dying..
Old Jul 3, 2007 | 01:49 PM
shietzitzkien's Avatar
shietzitzkien
Default my car keeps dying..
so i just replaced my spark plugs hoping that'll be the problem but its still dying. when i first start my car its perfectly fine. but after that i drive for like 4 minz turn off the car. start it back up and it just dies. so i was wondering what you guys think i should do? the battery is new, i replaced the fuel pump, and im not really sure what else to do but to just go little by little and fix one thing at a time.
Old Jul 3, 2007 | 01:58 PM
btegra94's Avatar
btegra94
GS-AARRR!!!
sounds like fuel line, check the valve on the feul rail see if you are getting pressure, if you are not i would get a new feul filter,AEM is good, also your injectors could be spitting, that should clear it up if you still have problems PM me
Old Jul 3, 2007 | 03:02 PM
doobiexx928xx's Avatar
doobiexx928xx
B18 Bullet
Does the key stay on the "ON" position, or does it kick back to the ACC position?
Old Jul 3, 2007 | 10:45 PM
Difussion3's Avatar
Difussion3
Touge
alternator??
Old Jul 3, 2007 | 11:11 PM
shietzitzkien
it'll start but then the rpm will just go to zero after a couple of seconds. and thats if its my lucky day. if not it'll just start for one second then die. and i guess i'll just have to go one by one on the list to replace. thanks for the help.
Old Jul 4, 2007 | 07:52 AM
Fuse's Avatar
Fuse
Check spark, check fuel pressure at the time of failure.
Ignition switch may be kicking back^^^^.Alternator is a good idea^^^^^ you should see 12volts engine off and about 14volts engine running this is a quick test for the alternator.
Old Jul 5, 2007 | 01:45 PM
shietzitzkien
replaced and checked the spark stuff. still nothing. but i guess i'll be going for a new alternator as soon as my paycheck comes in. but thanks for all the help.
Old Jul 5, 2007 | 01:54 PM
doobiexx928xx
B18 Bullet
You should check out the ignition switch...
