Key wont stay..
Old May 13, 2007 | 08:39 PM
doobiexx928xx's Avatar
doobiexx928xx
B18 Bullet
Default Key wont stay..
My key wont stay on the "on" position when I start it. It goes to "acc" I had this problem like a couple of months ago. It was the contacts on the key cylinder, the mechanic grinded them and put the cylinder back together and it worked fine. my question is, do I have to buy the whole cylinder or could i get one of a similar car and try to fix it?
Old May 13, 2007 | 09:02 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would just replace the ignition switch. Find a donor car with a working ignition and a key and just replace it.
Old May 13, 2007 | 09:12 PM
doobiexx928xx
B18 Bullet
could i get one at a honda dealer?
Old May 13, 2007 | 09:35 PM
doobiexx928xx
B18 Bullet
are the internals the same in all the swithches from da9's
Old May 14, 2007 | 04:38 AM
m735is's Avatar
m735is
Sounds like the switch, not the tumbler. Any junkyards close by? Two screws on the back of the tumbler hold the switch on.
Just match all of the wiring-I tried to swap an 90 Integra's with my sons 88 Civic-alittle different.
But if your mechanic ground down something on the tumbler then you would need that too-with the matching key.
