blox
Old Apr 5, 2007 | 09:36 AM
Topend's Avatar
Topend
scooted
Default blox
so if i buy a blox ssim for 00 gsr, can i use my original fuel rail, reg, connectors, etc on it? The ad said that its specifically for a b18c1 gsr motor.
Old Apr 5, 2007 | 09:43 AM
dubcac's Avatar
dubcac
I
Yes
Old Apr 5, 2007 | 10:37 AM
2001TEGGSR's Avatar
2001TEGGSR
Unless you have other supporting mods, I would recomend staying away from anything other than the OEM B18C1 intake manifold. You will notice a decrease in midrange torque, and a need to rev higher in order to make power.
At the very least, buy your tunning solution first and raise the Vtec engagement point.
Old Apr 5, 2007 | 11:58 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
You will need an ITR throttle cable bracket, ITR throttle cable, and non-GSR throttle pulley to run the throttle cable correctly without interfering with the hood or strut bar.
I agree with 2001TEGGSR. Until you have cams or other modifications that require more air, you will notice a very soggy powerband.
Old Apr 5, 2007 | 11:59 AM
redGSRguy's Avatar
redGSRguy
I think topend was the guy that is going to buy a bunch of other stuff as well. I could be mistaken though.
You will need a new intake as well as a b16/ls/itr throttle body cable for a clean install. You can keep your old stuff and ghetto rig it also.
Old Apr 7, 2007 | 07:21 AM
Topend's Avatar
Topend
scooted
yeah I was going to buy other stuff but seriously, im starting to see why everybody goes boost. for the same "finished" price or lower I can have like 20-50% more power over NA build and a stock, relaible motor. I better start $h!t*in money or something cause i LOVE the sound of a well built NA honda motor.
Old Apr 7, 2007 | 12:33 PM
1turbodc2's Avatar
1turbodc2
got boost?
it it is a short ram he won't need a new one, if it is cold air yes he will
