b18 block with b16 head??
Old Mar 31, 2007 | 10:34 AM
fresh860's Avatar
fresh860
non-vtec
Default b18 block with b16 head??
my neighbor was b/s with me today.. an he said that you could do a b18block with the b16 head an get more torque... now how true is he?? an is that even possible??
Old Mar 31, 2007 | 11:23 AM
Snoopy's Avatar
Snoopy
been there done that
which b18 block?
a b18a/b block and b16 head is an lsvtec and if not done right will blow up in your face
a b18c1 block and b16 head is a poormans type r and will drop your compression by .2cr points
Old Mar 31, 2007 | 11:29 AM
fresh860's Avatar
fresh860
non-vtec
b18 non vtec... an i believe b16 vtec..
Old Mar 31, 2007 | 11:31 AM
Snoopy's Avatar
Snoopy
Old Apr 1, 2007 | 11:55 AM
Rooftop voter's Avatar
Rooftop voter
But if it is done properly by someone who knows what they're doing, it's a good motor.
Old Apr 1, 2007 | 04:59 PM
g290ls's Avatar
g290ls
they call me tater salad
lol thats the start of a ls/v conversion my friend
http://www.sportcompactcarweb.com/te...s_vtech_engine
evertything that is needed enjoy !!!!!!!
Old Dec 10, 2007 | 04:41 PM
JeremybellRS's Avatar
JeremybellRS
is there a b16 non v-tec that will fit on a B18A block?
Old Dec 10, 2007 | 08:34 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
No.
The B16* family are all VTEC motors.
If you need a non-VTEC head for your B18A, pick up a B18B1 head.
Old Dec 13, 2007 | 10:29 AM
ricehnda94's Avatar
ricehnda94
Mcgyver
hey the b16, b18c1 combo, sounds interesting. Does it have the same kind of power as a type R. If you milled the head wouldn't that make up for the loss of compression? Are there any advantages to this type of setup? Like is it cheaper? Better for N/A applications, of turbo? Has anyone done a hybrid like that before?
Old Dec 13, 2007 | 04:21 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It will lack the same power of the B18C5 because it is lacking the aggressive ITR cams, a mild port and polish of the head, and will have a compression ratio of 9.8:1 compared to 10.6:1. Milling the head is a great way to ruin a perfectly good head, but that is just my personal opinion about it. I would prefer to swap out the pistons to increase the compression.
If you do this to a stock B18C1, you will lower the compression ratio and lose some power, especially if you use the B16 cams. If you had a head and block lying around and were looking to build a motor, it could definitely be a potent combination.
