OS pistons
Old Mar 20, 2007 | 08:34 AM
Topend's Avatar
Topend
scooted
Default OS pistons
will p30 oversized pistons fit in the stock bore of a B18C1? Does it just give closer clearance measures?
Old Mar 20, 2007 | 08:39 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Nope. You need to have it bored to 81.5 mm.
Old Mar 20, 2007 | 09:14 AM
Topend's Avatar
Topend
scooted
whats the benefit? why not just go with regular sized pistons?
Old Mar 20, 2007 | 09:49 AM
FooD2000's Avatar
FooD2000
Still Water
Bigger pistions = more displacement,
More displacement = more power hp/tq.
all = more $$$
Old Mar 20, 2007 | 10:01 AM
Topend's Avatar
Topend
scooted
do stock pistons work for ctr cams in gsr? then I wouldn't need different pistons. I guess i want to bump compression from 10.1 to 11.1. can i get a smaller head gasket?
Old Mar 20, 2007 | 10:44 AM
Provocateur
On permanent hiatus
all = more $$$
The difference in bore and subsequent torque numbers from using oversized pistons compared to standard pistons is going to be very negligible. Unless you sleeve and bore out a substantial amount like 84mm, you aren't going to notice any difference.
The main reason people use oversized pistons is so they can slightly bore out the cylinders to correct out-of-round, large scratches that cannot be buffed out with a light hone, and tapered cylinders.
Why not just get a standard bore OEM piston with higher compression ratio?
CTR cams will work fine at the stock 10:1 compression ratio, but a higher compression setup will benefit more from them, of course.
A thinner head gasket isn't the best idea. It will work but it won't increase compression very much to make it worth it and it will be thinner, making it more prone to blowouts. If you are going to do the head gasket, take another hour, drop the oil pan, and swap the pistons instead.
