test pipe?
Old Mar 13, 2007 | 10:47 AM
Topend's Avatar
Topend
scooted
Default test pipe?
rumor has it that where i live they might be getting rid of emissions. If this is true, should i run a test pipe in place of my cat, or still stick with a cat but of the high flow kind? Im not even sure test pipes come with an o2 sensor port but if they do, where can i find them? guess it wouldn't hurt to know where to buy high flow cats either. suggestions?
Old Mar 13, 2007 | 10:55 AM
Snoopy's Avatar
Snoopy
been there done that
stick with a high flow cat. you get minimal gains with a test pipe unless you have a heavily built setup.
www.sms-products.com
Old Mar 13, 2007 | 11:29 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Fuck the idea of having breathable air, you need 5 to 7 more hp. :shake:
Pardon me for being blunt, but run a high-flow cat.
in fact, if all you've got is bolt-ons, there's little point in spending $400 on a high-flow until you've gone deeper into your build.
Old Mar 13, 2007 | 04:35 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
There are no emissions tests here but I would never even consider running without a catalytic converter.
Besides the obvious poisoning of the environment for a minimal amount of power, your car will sound and smell absolutely awful. Not only that, but regardless of having or not having emissions testing in your area, it is a federal crime to tamper with or remove the catalytic converter. If you are caught, you could potentially face several thousand dollars in fines.
I am just using a generic 2.5" Magnaflow high flow cat that I bought off kteller (I wouldn't recommend buying from them, though ) for ~$100 and had a muffler shop weld on some flanges to work with my downpipe/exhaust setup. You will also need to have O2 bungs welded in if you need them.
Old Mar 13, 2007 | 05:49 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I agree w/the veterans here. Running catless is for the most part pointless and unhealthy overall.
Old Mar 15, 2007 | 06:51 PM
Topend's Avatar
Topend
scooted
did some research. Bad idea. Just wondering cause some guy in a 4 door gsr was pullin my friends SH and all he had was i/h/test. 2 people in each car so i thought it was weird... but yeah, ill go with a high flow when i get the motor built up. the stock cat won't bottle-neck the flow if i go with a cat-back? would be I/H/stock cat/CB
Old Mar 15, 2007 | 06:55 PM
Spec R's Avatar
Spec R
bah even if the stock cat is a "bottleneck" wooooo what are u losing, like 2-3 hp if that
DB Squad
Integra Forum Moderator
Old Mar 15, 2007 | 07:28 PM
Provocateur
On permanent hiatus
Very true. Stock Honda cats flow very well. The major restriction of the stock cat is the piping. 2" is very restrictive if one is looking to have a free flowing exhaust.
