Rings for Nitrous
Old Feb 10, 2007 | 11:48 PM
WhiteGhost's Avatar
WhiteGhost
Default Rings for Nitrous
I am in the process of replacing the piston rings on my 94 ls, and I'm also considering something good for nitrous application. I heard about gas nitrite coated rings, are they any good? Or will it be just fine If I use chrome rings?
Old Feb 11, 2007 | 09:38 AM
Zedron's Avatar
Zedron
Turbo B20
If you are going to do that replace the pistons. I has a LS and was spraying a 75 wet on it. Not exactly sure on how long I was using it like that but when it came time to do my motor swap for a turbo set up I got to see the stock pistons. I am surprised the motor still ran as strong as it did. They defiantly had some heat damage to them.
Old Feb 11, 2007 | 02:12 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The stock rings will be more than sufficient.
Old Feb 12, 2007 | 02:32 AM
WhiteGhost's Avatar
WhiteGhost
I'm considering the ZEX kit for max 75hp dry.
Old Feb 12, 2007 | 11:30 AM
Snoopy's Avatar
Snoopy
been there done that
if you're considering nitrous get a wet kit. they're much safer than a dry system.
Old Feb 12, 2007 | 08:52 PM
WhiteGhost's Avatar
WhiteGhost
That's weird! Because I thought the dry kit is the better choice for anything below 75.
Old Feb 12, 2007 | 09:44 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Our manifolds are designed to distribute dry air, not fuel held in suspension.
Long before I came to HAN, I ran a 75 wet shot on my GTi and paid the price.
I would vote for the ZEX dry kit, but jet it down to 55hp and use a window switch.
