installing side markers
Old Feb 9, 2007 | 04:15 PM
hmgemperor2003's Avatar
hmgemperor2003
Default installing side markers
Does anyone know how to install side markers for a 94 acura integra?
Old Feb 9, 2007 | 04:30 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
1) Measure & mark fenders.
2) Mount on / to fenders.
3) Wire to positive & negative lead on OEM turnsignals.
4) Consume alcohol.
It's all rather straightforward, really. h:
Old Feb 13, 2007 | 04:00 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
You have to really measure your fender to find a centerpoint that is accurate. Otherwise they will be uneven on both sides. I decided where I wanted to install the sidemarker and then made a latex template from there so that it stayed in place and was even while I made my cut.
So your gonna want to get a dremel for that with a shitload of cut off wheels. And remember to start small and work your way out, better to cut out too little then too much. If your using honda sidemarkers, they are fat on the backside with a hook slot and clip that relies on a good cut to secure it to the fender with no gaps. And the rest? Like Dave said...
Old Feb 13, 2007 | 06:44 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
ive got a great template that i found a long time ago when i did mine, enjoy, its exact!
jdmeg6hatchy
i
i didnt know if you knew, the 92-95 civic and 94-01 integra markers are all the same.
Old Feb 17, 2007 | 02:46 AM
oldboy's Avatar
oldboy
4) Consume alcohol.
lol
really was not expecting that as im reading it at 345am
Old Feb 17, 2007 | 10:45 AM
TheOtherDave™
Apathy Kills
Originally Posted by oldboy
lol
:chuckles: Just be sure you follow that order.
If step 4 is completed before step 1, you might not be happy with the results. h:
Old Feb 18, 2007 | 05:35 PM
hmgemperor2003
Default wiring side markers
i have some side markers and having a hard time wiring the wires. is the markers suppose to be on when i turn on the lights or the markers are only on when i turn on the turn signals? I try almost every combination so that the markers are on and blinking when i turn on the lights and using the turn signals. when the marker lights are on, i cannot signal. but when the marker lights is off, i can signal. any instruction on wiring? the markers are on a 94 acura integra gs-r.
Old Feb 19, 2007 | 02:13 AM
Schwa's Avatar
Schwa
Schiggity
Just pull out the ones used to connect to your amber corners, and splice those ones in. I think the clear corners have two bulbs, so you want to choose the bulbs that blink when you signal.
I don't think it is possible to have your markers blink as well as be on with the headlights unless there are two filaments in the bulb. I have mine wired so that they are my turn signals, rather than running lights.
Old Feb 19, 2007 | 01:57 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
The markers are supposed to be on only when the signal lights are blinking. I went the easy way out and just bought the JDM fenders that came with the side markers
