starter relay switch problem!!
Old Feb 1, 2007 | 10:48 AM
fresh860's Avatar
fresh860
non-vtec
Default starter relay switch problem!!
I just purchased my first acura... 1994 integra rs. it has one big problem!
the starter relay switch. my car will not start in the COLD!!! i have to keep trying to turn it over. i checked the starter its not that! i put it in gear, and keep trying to turn it over until it finally does. but when its 40 degrees or warmer it doesnt have a problem! my tegra has a b18c inside it which came from a 93 tegra. so?? my body being a 94 an the motor being a 90-93... what model/year do i buy a relay for????
please help!!!!!
Old Feb 1, 2007 | 11:24 AM
bnuk's Avatar
bnuk
so it turns over and won't start or won't turn over?
Old Feb 1, 2007 | 11:32 AM
2001TEGGSR's Avatar
2001TEGGSR
please help!!!!!
93 GSR's came with a b17, as far as I know. Buy the relay for a 94 integra rs.
Old Feb 1, 2007 | 11:50 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Yes... the motor is a B17A1.
That said... you should be using the OEM DC4 relay box, so a starter relay for a 94 RS will work.
Old Feb 1, 2007 | 12:00 PM
ginomobile/teg's Avatar
ginomobile/teg
did u check the CCA (cold cranking amps) on the battery, almost sounds like dead battery dude.
Old Feb 2, 2007 | 05:42 AM
fresh860's Avatar
fresh860
non-vtec
thanks everyone.... but still dont have the right answer
my motor is a b18c... a neighbor told me that it came from 90-93 tegra. is that true??? the battery is putting out 12v's, its a brand new battery. i checked the starter, it was fine. so i would buy a starter relay for a 94 rs? ok... i have checked napa, advance auto parts... an nothing, they both told me that i have to go to a acura dealership for that. but im all set with getting raped threw a dealership. today 2-2-07 it started right up... its bout 32 degrees out, so thats warm.. but anything below that it will not start. it turns over, but it does not start. the check engine light comes on, but it does not start... so is it the relay switch????
thanks
Old Feb 2, 2007 | 07:10 AM
bnuk's Avatar
bnuk
attatched is more info about the starting system than you probably wanted to know. I would do some diagnostics before going out and replacing anything because most of these components are pretty pricey. If you are familier with basic electronics and the operation of a relay it shouldn't take you more than an hour or two to pin down the problem. A solonoid and realy are essentially the same thing in this case. I would start with the easy stuff first, the clutch switch and the relay. Fortunatly because of the amount of current involved the starting circuit has to be pretty simple.
info is from the 98-01 FSM but should still be applicable.
File Type: zip
Old Feb 2, 2007 | 08:56 AM
TheOtherDave™
Apathy Kills
Also, since you have a CEL showing... pull the code.
Use the instructions in the Integra FAQ or get the guys at Napa or Auto Zone to pull it with their OBD-1 scanner. It may very well be related to your no-start condition.
Old Feb 2, 2007 | 09:14 AM
fresh860's Avatar
fresh860
non-vtec
well.... could u put that in english???? im not that qualified when it comes to cars. so if you could let me know what that ment and that could be the probelm
thankyou
Old Feb 2, 2007 | 09:22 AM
TheOtherDave™
Apathy Kills
thankyou
1) You mentioned that your "Check Engine" light is on (aka CEL).
2) That means that your car's ECU has logged an error code. Reading that code will help you fix your car.
3) Thus, go to NAPA and either rent an OBD-I scanner or follow the directions in the Integra FAQ to read the code yourself.
Better?
