Light weight flywheels
Old Jan 24, 2007 | 09:08 AM
Rooftop voter's Avatar
Rooftop voter
Default Light weight flywheels
I'm gonna be having a new clutch put in soon, and decided I might aswell just do the flywheel too. I was looking at an ACT streetlight. Any thoughts on these? I read somewhere that you don't wanna go under 14-or 12 pounds or they may shatter, the street light wieghs 12.8. Any Truth to this? Any recommendations?
Old Jan 24, 2007 | 09:17 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
I wouldn't worry about it shattering, that's more a concern with lightened factory flywheels. You'll hear opposite ends of the spectrum on this, I love my 8lb Fidanza. The power seems to always been there, it climbs through gears faster as well.
Old Jan 24, 2007 | 06:35 PM
hitman619's Avatar
hitman619
SDSU Basketball
"ACT streetlight flywheels" are pretty good
wouldn't worry to much about it shattering
Old Jan 25, 2007 | 06:34 AM
SpeedFreak07's Avatar
SpeedFreak07
Yeah... I would only worry about it shattering if you got it from a crappy manufacturer... you should be just fine.
Old Jan 25, 2007 | 08:33 AM
Topend's Avatar
Topend
scooted
Anybody have real knowledge like pros/cons? Im wondering too because the laws of physics say by taking away weight from a reciprocating assembly will not only allow it to be spun faster, but consequently to slow faster. if your playing around in a gear and let off the gas one would think the "engine brake" would jerk your head off. Soooo....anybody experience this?
Old Jan 25, 2007 | 12:11 PM
Snoopy's Avatar
Snoopy
been there done that
the lighter a flywheel is the faster the engine will rev up and down.
Old Jan 25, 2007 | 05:01 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
A lighter flywheel give you less bottom end and more top end. Grenading comes from mis alignment in most cases, but I have heard otherwise as well...as long as it is name brand you should be ok.
I just hand my clutch done today. Exedy OEM replacement and 8lb fidanza flywheel. I feel a difference in pedal feel but that is all for now. In about 488 miles I let you know what I think completely.
Old Jan 25, 2007 | 05:10 PM
ED9man's Avatar
ED9man
driver
I like my Exedy 9.5 lb The ring gear is milled, not pressed on. I think it makes the car easier to drive and it pulls and responds better at any rpm, I think it's easier to launch too actually.
Old Jan 25, 2007 | 05:33 PM
Rooftop voter
I think the street light is kind of a good middle ground between daily driving and racing at 12 pounds. THanks for the replies.
Old Jan 25, 2007 | 09:42 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I am running a 9lb Prolite and I wouldn't go any heavier. I don't see why you would want to go much heavier unless traction is an issue.
