What kind of clutch to get?
Old Jan 15, 2007 | 09:34 PM
bnyce2u's Avatar
bnyce2u
Default What kind of clutch to get?
hey guys i own integra gsr 200
i think i need a new clutch which one should i get ??
and just about how much should i spend for everything including installation???
Old Jan 15, 2007 | 09:35 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Unless you have mods that need a stronger clutch, OEM is your best option.
Old Jan 15, 2007 | 09:37 PM
DaGip's Avatar
DaGip
4N2Ner
if your car is stock or slightly modified i would just stick with OEM. with install it depends on the shop, but with parts & Labor it will exceed $600.
Old Jan 15, 2007 | 10:26 PM
Black Ack's Avatar
Black Ack
Black Acura Driver
The OEM clutch from Acura is definitely great quality, just a bit on the pricey side. Check out the the Exedy stage 1. It's a slight improvement over stock, and far less expensive. They also have an OEM equivalent, but I believe it's manufactured by a different company.
Old Jan 16, 2007 | 01:19 AM
TegXPro92's Avatar
TegXPro92
yes i have the exedy stage one, its basicly an OEM disk with a stronger pressure plate, and is easy to transition from stock, not like jumping into a 2 or 3, i havent had any issues, and i abuse the hell out of mine.
Old Jan 16, 2007 | 05:15 AM
Thecargoddess's Avatar
Thecargoddess
Fabulous Pie
I have this clutch and really easy to drive on- Nothing way drastic. I recommend it.
