Changing 5th Gear
Old Jan 10, 2007 | 08:03 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Default Changing 5th Gear
So I have a 95 GSR and I do alot of driving on the freeway. My trips range from 500 to 800 miles. I was wonder if anyone had changed there 5th gear to lower the RPM's to high speed?
If so, what was the overall final dive?
Old Jan 10, 2007 | 05:37 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You wouldn't save enough money in gas to justify the expense of swapping out the 5th gear.
Old Jan 11, 2007 | 07:52 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Thanks for the feedback. That kinda what I figured. I just feel bad for my motor.
Old Jan 11, 2007 | 09:52 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Just be religous about changing the oil every 3K to 3.5K.
And use a quality filter (i.e., not FRAM).
Old Jan 11, 2007 | 09:59 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
So what do you consider to be a quality filter?
Old Jan 11, 2007 | 10:32 AM
TheOtherDave™
Apathy Kills
Wix <-- I've been using them exclusively before I even bought my DC4.
Purolator
Mobil 1
Fram uses cardboard end caps, piss-poor filtration media and plastic bypass valves. All the brands I've listed use steel caps, more filtration media of better quality and steel bypass valves.
Check the FAQ... a good ways down, there's a link to a filter discussion / test on NTPOG. It's on the old link page way down near the bottom of the thread.
Old Jan 11, 2007 | 11:06 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
I have been using OEM filters, I work for a dealership and Acura is one of our car lines.
Old Jan 11, 2007 | 11:15 AM
TheOtherDave™
Apathy Kills
Then you should have no worries.
If it's the constant drone of 4K that's killing you, I'd look into sound deadening mat for the firewall and floorboards. As mentioned earlier, the cost of retrofitting the LS 5th gear would never be repaid in fuel economy.
Old Jan 11, 2007 | 04:15 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Purolator
Mobil 1
Never heard of Wix, where would I find that? How about K&N? Over rated?
Old Jan 12, 2007 | 01:39 AM
bonsaitree's Avatar
bonsaitree
you can buy a Wix label oil filter or you can go down to carquest and ask them for a red label Car quest oil filter....its the same thing Make sure you get the red label though, the blue label is different....wait dammit I mighta got the color backwards. Just go into Carquest and tell em you want the better Carquest oil filter.
