installing stock rad
Old Dec 8, 2006 | 02:24 PM
JIMMY YAYO's Avatar
JIMMY YAYO
Default installing stock rad
does anyone have a link on how to install a stock rad and what materials i will need?
Old Dec 8, 2006 | 02:33 PM
2001TEGGSR's Avatar
2001TEGGSR
it's very simple..
Drain coolant
Disconnect the large radiator hoses
Disconnect the electrical connectors for the fan's
Remove upper Radiator mounts
Should come right out.
A Helm's or Haynes manual will have pictures.
Old Dec 8, 2006 | 03:06 PM
tommyhcky13's Avatar
tommyhcky13
10 mm socket and drain pan, and lots of towels. then you cant LEGALLY dump it in a ditch but go ahead anyway
Old Dec 8, 2006 | 03:26 PM
Driverman5777's Avatar
Driverman5777
its a sinch.... just a lil bit of a tight fit... what kinda of tranny do you have?
Old Dec 8, 2006 | 05:27 PM
FooD2000's Avatar
FooD2000
Still Water
good ol' Team Integra's DIY: http://www.team-integra.net/sections...?ArticleID=520
Old Dec 9, 2006 | 05:29 AM
JIMMY YAYO's Avatar
JIMMY YAYO
5 sp
Old Dec 9, 2006 | 06:03 AM
Driverman5777
it should be a easy than all you have to do is undo the top and rear rad fluid hoses, and unhook the electrical connectors, and unbolt the top 2 mounting bolts, all of this of course after it has been drained... then it just comes right out
Old Dec 9, 2006 | 09:12 AM
1turbodc2's Avatar
1turbodc2
got boost?
wow u are a fucking retard, taken it to your local auto parts store is that hard for you??? So they dispose of it correctly???
Old Dec 9, 2006 | 03:35 PM
2001TEGGSR's Avatar
2001TEGGSR
Yes, I would definitely dispose of the anti-freeze properly. Drain it into a pan, and store it in milk jugs or laundry detergent jugs until you can take it somewhere. Pep boys usually takes it for free. Same with oil.
Anti-Freeze can kill dog's, cat's and other pets. Not to mention, you don't want it seeping into our fresh, drinking water supply.
Old Dec 9, 2006 | 03:38 PM
FooD2000's Avatar
FooD2000
Still Water
^ you also get 40cents per gallon for disposing of oil at Autozone. 2.5 gallons and you'll have a dollar to put towards gas!
I know because i work there, but i generally keep that secret from the customers (customers are dirty bastards).
