GSR exhaust VS. ITR exhaust
Old Oct 1, 2002 | 07:14 PM
evo119's Avatar
evo119
GO GIANTS!
Default GSR exhaust VS. ITR exhaust
Had a quick question.....I'm a lil tired of the aftermarket exhausts nowadays...getting a lil old ....so I was wondering if an ITR cat back exhaust would bolt up to my 95 GSR with no problems. Is the piping the same, and will it fit onto my cat? Or do you think it's a waste of money? Any ideas or opinions would be appreciated...thanks
Old Oct 1, 2002 | 07:56 PM
DB7 2.0's Avatar
DB7 2.0
Banned
the ITR piping might be a lil bit longer i think.
Old Oct 1, 2002 | 08:11 PM
b00gers's Avatar
b00gers
the ITR have better flow numbers than the GSR.
Old Oct 1, 2002 | 08:16 PM
Black2KGSR's Avatar
Black2KGSR
no...it won't bolt up. you have to get the piping slightly modified.
evo119's Avatar
evo119
GO GIANTS!
so...a muffler shop could just cut it and reweld the flange right?
Old Oct 1, 2002 | 08:17 PM
Black2KGSR's Avatar
Black2KGSR
probably. unless it's shorter. :dunno:
Old Oct 2, 2002 | 05:53 AM
BSQ's Avatar
BSQ
The Type-R Cat-back exhaust is 57.2mm (2.25") mandrel bent piping [an increase of +6.4mm~8.6mm over stock] throughout to increase air flow. The muffler is a multi-chamber design, and does a wonderful job of dissipating sound. However, the funnel-shaped piping in-between the chambers makes it a very free-flowing exhaust. Furthermore, in order to lighten/strengthen the parts, stainless steel was used.
The B-pipe will need to be extended 4.5" if it is installed on a '94-'99 GS-R because it has a shorter cat than the other Integras.
Old Oct 2, 2002 | 08:46 AM
evo119's Avatar
evo119
GO GIANTS!
Thanks for all the info!!! Much appreciated
Old Oct 2, 2002 | 08:49 AM
evo119's Avatar
evo119
GO GIANTS!
So if I extend the piping, will it line up to the cat? I have a feeling I would need a new cat. And if I do, then do I need an ITR header?
Basically, can I just bolt up the ITR exhaust to the cat. or do I need the ENTIRE system, header, cat and exhaust?
Old Oct 2, 2002 | 01:57 PM
dubcac's Avatar
dubcac
I
You need to extend the piping from the ITR catback to fit on the GSR. Any competent muffler shop can do this.
