i need help tightening bolts on ball joints on uca and lca
Old Nov 11, 2006 | 09:26 AM
adk683's Avatar
adk683
Default i need help tightening bolts on ball joints on uca and lca
i just put in new lug studs and what is the easiest and best way to tighten down nuts on ball joints all they do is spin and the nuts are being kind off stubborn any help to make this easier would be appreciated
Old Nov 11, 2006 | 12:23 PM
adk683's Avatar
adk683
what happens if ur threads on ur tie rod end and lca bolt are kind of messed up and u cant get the bolts on what can u do about it do u have to replace all of it or what any help appreciated
Old Nov 11, 2006 | 05:51 PM
2001TEGGSR's Avatar
2001TEGGSR
Get a thread chaser. Part of a Tap & Die set.
Old Nov 13, 2006 | 04:53 AM
fjm1's Avatar
fjm1
G35
Re-threading won't help if the ball joint bolts are spinning. I know for the lower if you put the wheel on and let the car sit on the suspension it puts pressure on the ball joint/bolt. This may stop it from spinning and allow you to put the bolt back on/rethread with the Tap & Die mentioned by 2001TEGGSR.
I had a similar problem, but it was when I would go to get the final torque specs on the bolt. I put a jack under the control arm and gave that corner some weight. This worked for me.
Air tools/impact gun will also help alot.
Old Nov 13, 2006 | 08:51 AM
bnuk's Avatar
bnuk
Rethreadig should work, if you have less friction in the threads that the ball joint, you are golden. You can also try a new nut and some WD-40. DO NOT try to put weight on that wheel, fjm has it backwards. if put weight on it, it will pull the ball joint out and things could get ugly. what you want to do is while it is on the jacks stands, take your jack and push up on the LCA like he says, that wil put more pressure on the bal joint. Push the LCA up to where the spring is compressed, but not to where the car coming off the jack stand.
for the UCA, it moves freely so putting weight on car/pushing on LCA won't help. what you can do is take a big clamp and push UCA and hub together to create that friction
Old Nov 15, 2006 | 09:46 AM
adk683's Avatar
adk683
ok i was able to rethread the lower ball joint with the original nut but i cant figure out how to fix tie rod end i really dont want to buy a tap and die set but i might if so what size would i need
Old Nov 15, 2006 | 10:33 AM
2001TEGGSR's Avatar
2001TEGGSR
You can buy individual tap's & thread chaser's. Just take the nut with you and match it to that. I'm not sure on the exact size.
An entire set is important when working on a car, personally I would invest in one.
Old Nov 15, 2006 | 12:52 PM
bnuk's Avatar
bnuk
you'll have a hard time finding the individual taps, most of the stuff on honda's is fine or "super fine" metric thread. yeah if you find a good set that includes the fine threads let me know.
Old Nov 16, 2006 | 09:17 AM
adk683's Avatar
adk683
well i just bought a new tie rod end because i got it for 21 dollars and i figured save me a lot less trouble but the old one is fused on there good does anyone got any good ideas on how to get it off there easily
Old Nov 16, 2006 | 09:44 AM
2001TEGGSR's Avatar
2001TEGGSR
I bought a complete Craftsman Metric set, around 100$. I have yet to need a size that was not included in the kit. I rebuilt my entire bottom end, had to chase every single hole and re-used bolt. :shrug:
